how do i take the dash out?
It's not hard to do just takes time start with glove box then pass airbag ,airbag is connected up with a yellow plug take care when Removing this,steering wheel next ,behind all the airvents are screws as well ,all the stereo and heater controls Need to b removed use a flat headed screw driver to pop the vents out,now open bonnet remove the rain tray were your windscreen wipers are you will find a screw at each end these screws go through the bulkhead one comes out from were u removed the pass airbag I also removed the part that goes round the gearstick handbreak as it was easier to remove the dash it's only a rough guide this any pics needed email me as I have lots good luck
It's not hard to do just takes time start with glove box then pass airbag ' date='airbag is connected up with a yellow plug take care when Removing this,steering wheel next ,behind all the airvents are screws as well ,all the stereo and heater controls Need to b removed use a flat headed screw driver to pop the vents out,now open bonnet remove the rain tray were your windscreen wipers are you will find a screw at each end these screws go through the bulkhead one comes out from were u removed the pass airbag I also removed the part that goes round the gearstick handbreak as it was easier to remove the dash it's only a rough guide this any pics needed email me as I have lots good luck
What this man said (H)
Steering Wheel doesn't NEED to come out, but it's a lot easier if you do! :)
