engine temp reading -49 on VAG?????
hi had the car plugged in today to find out what is causing my vr to idle at around 1800rpm and the only thing that we could find using VAG is it saying that the ambient outside temperature is -49 with only the ignition on but when the engine is running then it jumps up to the correct temperature that the engine is running at??
could this cause itt to rev high??
where can i get the 2 yellow and blue sensors from??
