What shell to use???
Hi there,
I have a vr6 engine and im looking to put it into a mk2 but im unsure what body to use. I know if i use a mk2 gti shell then i need to weld the front mount solid and move the back one forward slightly but what in terms of fabrication would i need to do if i use a mk2 1.3 or driver shell or is this even possible??
All comments are grately appreciated,
Thanks Jake.
  • 4 months later...
Use a mk2 gti 90 spec shell and swap the subframe for a mk3 vr6 one then use either a vibratnics mk2 vr6 front mount or one from ebay the seller is also is a member on mk2vr6 and the vr6 engine will droo straight in no welding needed as said above use a 90 spec car as the loom is pkug and play altough you will need to modify it i.e headlight connections etc
