bran23 0 Posted October 21, 2010 Report Share Posted October 21, 2010 Hi all I'm getting my clutch done next week and having the timing chains done at the same time is there anything that normally bteaks or needs doing while this is being done thanks for any help Link to post Share on other sites
p0u1 14 Posted October 21, 2010 Report Share Posted October 21, 2010 the chain guides, just use a "timing chain kit" should have everything there, be carfule not to brake the head gasket when you take the timeing chain cover off Link to post Share on other sites
russj249 2 Posted October 21, 2010 Report Share Posted October 21, 2010 might as well put a rear main oil seal in too.. only about 10 quid and takes minutes to do. be careful when removing the thermostat housing as they can be brittle and crack when you take it off. Link to post Share on other sites
