merlin2002 0 Posted October 18, 2010 Report Share Posted October 18, 2010 HiJust wondering if anyone has had any experiance with 5mm wheel spacers on the front of a VR6?my questions are.Did you use non hubcentric typeDid you use longer boltsDid you have any problems afterany thoughts would be great!ThanksRob Link to post Share on other sites
Ian_rogers 0 Posted October 18, 2010 Report Share Posted October 18, 2010 I used 5mm for a while, they were crappy ripspeed jobbies (multi-fit) as needed some quick, I just used standard bolts n were no problem Link to post Share on other sites
b19drg 0 Posted October 18, 2010 Report Share Posted October 18, 2010 Im running 5mm universal spacer up front , you will need to get longer wheel bolts as standard bolts will only give you about 4 turns which aint enough . Link to post Share on other sites
Rustyman 0 Posted October 18, 2010 Report Share Posted October 18, 2010 How much are spacers ?? If i do bung my BBS back on how big a spacer should i use ?? My tt wheels fit pefect the old VR6 x spoke BBS sit too far in .... Grrrrr Link to post Share on other sites
