JAZZ MK3 0 Posted September 6, 2010 Report Share Posted September 6, 2010 drivers side works when it feels like it , other side is fine .its either got power which then works fine or no power , cant hear motor grinding etr.going to check the chassis plug for broken connections but have a feeing it might be the motor as when i give it a smack it works again or when i knock the glass it works ok then too.im ruling out the reg mech for now because if it was that then surely i would here the motor even if the window was jot moving ???any suggestions ???? Link to post Share on other sites
sabs12 0 Posted September 6, 2010 Report Share Posted September 6, 2010 i have the same problem. driver side plays up. passenger is fine. not sure what it is Link to post Share on other sites
JAZZ MK3 0 Posted September 6, 2010 Author Report Share Posted September 6, 2010 im looking inot mine this weekend will post results herewell mine is an after market kit , installed about 8 years ago , spoke to the co hat fitted it and told them the symptoms , they ruled out wiring as its direct through chassis socket , no connectons , they suggest sticky motor or sticky mech , will know for sure soon. Link to post Share on other sites
Lukey. 381 Posted September 6, 2010 Report Share Posted September 6, 2010 they are fairly easy to take to bits to find out whats wrong, if the reel was binding you wouldnt hear the motor, the cable could be knotted up inside the reel. They are a sight harder to put back together by yourself Link to post Share on other sites
