My 1995 Corrado - and a bit of refurbishing - story
Just thought I'd add my thread here as well - it's a bit old "thread" so timline isn't necesarrely correct now :)
I picked up this Brombeer 95 VR6 from Stockholm - Sweden (2008), it's a bit hard to start, but haven't been able to go over it properly yet.......drove it about 1000 km from Stockholm to Bergen - Norway.
The pics are quite bad, as I haven't taken any pics of it myselfe yet, but this is how it looked while it was still swedish...:)
corrado011.jpg?t=1267390141
corrado012.jpg?t=1267390142
corrado013.jpg?t=1267390142
Funny story about this car though, was never sold as a new car as it was in use by Volkswagen themselves, according to VW Automuseum (long story short, due to registration in Norway, I tried to find a first date for registration in Germany, wich doesn't seem to exsist, as VW doesn't register these cars on a "normal" german plate).
It got pretty much all equipment, besides leather. It got sunroof, AC, double airbags etc, and it's done about 119000 Km, and got a full service record.
Gona do the chain replacement before I register it in Norway, so it most likely will be sitting until next summer...:) (Not planning on using it on norwegian SALTY roads during winter time....:) )
Some small updates - things takes time....:)
Subframe almost finished assembled, with new R32 rear bushings, new front bushings:
New ball joint and swaybar end link:
The wheelhub and dirt shields:
More dirt shields and wheelhubs:
And finaly a bad shot of the wheel"house" with new Volkswagen Long life Underseal:
All parts from the Stealer...;)
Maybe the colors are a bit more correct here then the previouse pix - it still got some "spark" to it though...lol
Oil sump:
DSC_4032.jpg?t=1256930990
DSC_4033.jpg?t=1256930990
The heat shield in the rear fender:
DSC_4034.jpg?t=1256930991
Heat shield over the exhaust manifold:
DSC_4035.jpg?t=1256930992
Engine cover:
DSC_4037.jpg?t=1256931003
Exhaust manifold:
DSC_4039.jpg?t=1256931005
Engine mount:
DSC_4040.jpg?t=1256931006
Bracket:
DSC_4041.jpg?t=1256931007
Oil filter housing:
DSC_4041.jpg?t=1256931008
DSC_4051.jpg?t=1256931016
Lower intake minifold:
DSC_4044.jpg?t=1256931009
Intake manifold:
DSC_4045.jpg?t=1256931010
DSC_4050.jpg?t=1256931014
The engine is now almost ready, the chain have been done, new lifters, new valve stem seals, MK4 head gasket, new stainless crack pipe, all new plastic (thermostat housing etc), all new sensors on the oil-filter housing, and in thermostat housing. it's pretty much assembled only missing the crack pipe/thermostat housing + a few other bits a pieces.
The block have also been etched primed and painted with anthracite gray.
Some bad phone pics from the painting:
Etch primer:
27112009220.jpg?t=1259348505
27112009221.jpg?t=1259348505
27112009222.jpg?t=1259348506
And the anthracite gray paint (2 coatings) (I did 3 thin coats - but pics taken after second painting) (it's currently drying up the last layer)..;)
27112009223.jpg?t=1259348513
27112009225.jpg?t=1259348515
27112009227.jpg?t=1259348517
27112009229.jpg?t=1259348518
Also managed to fit the front "drivetrain"
Got the drivetrain re-fitted, and it's now able to stand by itselfe :) (Today - so a small mile stone).
The rear axel ready to go on - brakes refurbished at Bigg red and everything else is new (don't mind the old brake line - it's getting replaced)...:)
Looks like it could do with a small scrub:
And no - it's not the rims I plan to use :)
Finaly some real progress being done on this Corrado.
- Got new brake lines and hoses +++ fitted (going to have to get some new OEM VW brake hoses though as the goodridge stuff I bought is total cr** IMHO - the rear was wrong, and the front ones (one side) doesn't seem to hold the seal properly...:( ).
- Got the engine fitted in the car - still some electric to be connected, and some of the water hoses etc.
- Missing the air-intake as I lost the gasket between the TB and the air intake - new one ordered.
- Partly fitted the Hartmann Exhaust system - missing the midle "pipe" as I have to cut it to fit.
Some pics of the progress:
As it sits tonight:
The Hartmann Exhaust:
And finaly a somewhat to dark photo from the bay:
Just thought I'd put in a few pics of it after the registration - better photo's to come eventually - have been to busy driving it to get time for another wash and a "photoshot" :)
YES! I know it sits to high - will also be adjusted a bit down on the height ;)
thnx m8 - pretty much a standard C, but tried to get it up to the standard it was in when first entering the streets....lol..:)
hopefully gone a bit beyond that - for me it's a summer car as the salty roads of Norway would tear it apart within a few years....:)
thnx guys!
Realy not that much of plans further - although most likely a "never ending" project so will be small things done I guess.
Will keep it standard OEM car.
Will have to adjust down those coils though....:)
And figiure out a little "starting problem" - sometimes have to crank for quite some time before it fires - it always starts though....:)
