muttley 0 Posted August 15, 2010 Report Share Posted August 15, 2010 hi guysi'm taking delivery of the doner car for my mk2 golf conversion on wednesday afternoon, a 97 Vento Vr6 which had previously been converted from an auto to a manuel gearbox and is running a cable change conversion.1 thing i do have to do is work out a running problem that it has had since the change, maybe you guys could help meThis is all the info i know as i wasn't there when it was done.after the conversion was done the engine wont start, not even a click. the petrol pump can be heard to start up but nothing else is happening but it was fine before hand.The engine was in when the conversion was done and the fly wheel, pedal box, clutch, and starter were changed also. I havn't personally seen the car since but i know it was running with no problem before.any ideas? Link to post Share on other sites
daxmatt 0 Posted August 16, 2010 Report Share Posted August 16, 2010 Was the ecu changed or reprogrammed, if not theres were to startcheers matt Link to post Share on other sites
p0u1 14 Posted October 18, 2010 Report Share Posted October 18, 2010 if its not clicking then the ignision switch is not sending 12v to the starter motor relay, you have two positive wires going to the starter mottor the small one been the relay as well as the solinode to engage te starter motor, if you have no click its something to do with that Link to post Share on other sites
