supadupagt4 0 Posted August 8, 2010 Report Share Posted August 8, 2010 do they remove the windscreen? if yes, how and what happens if they break it? Link to post Share on other sites
T0NYVR6 2 Posted August 8, 2010 Report Share Posted August 8, 2010 They'll just mask it up mate! Link to post Share on other sites
Nero Mk 2 8 Posted August 8, 2010 Report Share Posted August 8, 2010 A good quality spray shop should take it out, all glass out panels off ect,a cheap spray shop will mask everything off Link to post Share on other sites
xyber 1 Posted August 8, 2010 Report Share Posted August 8, 2010 Screen out, worth doing as normally behind the screen is rusted to fuck where water sits behind it so it's a good chance to sort that and stop it creeping out on show on a new paint job.It's glued in so it cut out and if it breaks it's tough luck. Got to be done though. You can cheat on the rear glass. There's a tape you can get with a plastic strip on it that you slide under the seal and tape to the window. It's pulls the seal out of the way so you can get paint in there. Link to post Share on other sites
