Power cable for amplified bee sting aerial
i thought it connected via the block you could just run a new ignition live feed to it or a feed that comes of the blue wire (its normally blue anyway ) that turns the amps on if you are running an amp see if you can see a blue wire on the stereo output into the block and see if there is a wire connected to it
ok had a look at my ISO Harness & got the following.
Brown = Negative, Red \ White Perm Live, Grey \ White = Ilumination, Brown \ Red = Ignition Live
& White \ Blue - Which I assume should be the power for the aerial?
There is also a plain blue wire but it looks this is the amp trigger left in by the prvious owner as I can see the end of it in the boot. Not sure if he would have tapped that into the aerial power?
yes i neglected to put there are essentially the same thing, but blue if it was there then might as well use it, :-)
dont get your hopes up for awesome signal everywhere though, a lot of the time they make slight improvement only
