HELP 02m gearbox oil
Be sure to undo the filling plug before you do the drain plug just in case. I had to move the pipe on my 4 motion but you may not have to. The plugs are a torx style fitting and I had to borrow one. If your car is on a level surface then fill until issuing from the filling plug.
