ashmk3 0 Posted June 25, 2010 Report Share Posted June 25, 2010 Right I have come to the conclusion my head gasket is on it's way out, White smoke from exhaust quick coolant warm up and building alot of pressure. So my question is what is needed for head gasket change? Am I right in thinking:head gaskethead bolts(how much am I looking for arpscheck head for warpagecheck valves etc for wear and tearI'll look at the chains too. Is this all? Link to post Share on other sites
golfrabbit33 0 Posted June 25, 2010 Report Share Posted June 25, 2010 arp headbolts are only needed if you intend to take the head off again. if yes then c2 motorsport on here do all arp`s . a gasket scraper wouldnt go a miss to get the baked gunk off. Link to post Share on other sites
ashmk3 0 Posted June 26, 2010 Author Report Share Posted June 26, 2010 Well I don't really want to have to take it off again. I have seen some on eBay but they come from America. Link to post Share on other sites
lewi2006 0 Posted June 26, 2010 Report Share Posted June 26, 2010 ive just done my gasket gsf do the head bolt set only 22 quid got my head gasket from the states because they done the 12v vr6 in the mk4 golf and its metal try www.intengineering.com/mk4-head-gasket-for-12v-p8591343.html Link to post Share on other sites
ashmk3 0 Posted June 26, 2010 Author Report Share Posted June 26, 2010 You had any problems with the bolts or they holding fine? Link to post Share on other sites
golfrabbit33 0 Posted June 27, 2010 Report Share Posted June 27, 2010 standard is fine if standard power, c2 motorsprort uk can get metal gaskets Link to post Share on other sites
ashmk3 0 Posted June 27, 2010 Author Report Share Posted June 27, 2010 I shall give them a call then. What advantages are there over using standard gaskets to metal ones ? Link to post Share on other sites
lewi2006 0 Posted June 28, 2010 Report Share Posted June 28, 2010 not had any problems with the head bolts check the link above for the benifits of a metal gasket Link to post Share on other sites
