Well seeing as I may be doing the headgasket in the near future I was thinking of upgrading to arp bolts etc. but I was thinking could I use a spacer gasket on the head and lower the compression ratio. As I wouldn't
mind going boost at some point. I was just wondering can a n/a engine cope with lowered compression what are the pros and cons of this?
ahh right then if its head gasket then its been decided i go low comp :) but i think my aux water pump could be causing the excessesive pressure in my cooling system, i refilled the coolant and found no oil in there touch wood.
