Easy, front bumper off, drain oil and coolant, fit new heat exchanger that lives on the front of the engine above the oil filter, refill fluids, flush the coolant through, drain and refill with G12. Probably cost you £70 max for the lot if you DIY it and a mornings work.
Worth scanning first though to see if any codes point to something else
  • 10 months later...
