After driving to Birmingham on Friday from Oxford, I got a fair bit of smoke coming out of the engine bay when i pulled up. At first I thought it was the coolant hose that i replaced has split again but that was solid, the smell was also of oil. It was coming from the underside of where the two exhaust pipes go into one on the rear of the engine bay. What could be causing oil to flick on this and smoke?
If it is the driveshaft (gator or otherwise) how big a job is taking the drive shaft out and is there a guide on here anywhere??
Thanks,
Ian
