vr6stormt 0 Posted June 10, 2010 Report Share Posted June 10, 2010 cant find any answers to this prob.....the other day when i was checking levels i noticed the coolant bottle had thick black oil in it i checked the engine no water in there it dosent over heat no performance drop nothing is there any thing else apart from head gasket where the oil could get into the water side of things any help would be great thanks.... Link to post Share on other sites
Pearsy47 1 Posted June 10, 2010 Report Share Posted June 10, 2010 like you said mate thats the only way oil could get in with the expansion tank is the head gasket its not that bad of a job i ve done it before when i bent 7 valves ! lol Link to post Share on other sites
vr6stormt 0 Posted June 10, 2010 Author Report Share Posted June 10, 2010 yeah i was just getting thrown cos its all working still and not showing normal head gasket signs but i just got some goodys from tps both chains all guides an tensioner full engine gasket set and clutch kit got tomorrow of work so long weekend i think lol am i going to need a hoist? Link to post Share on other sites
Pearsy47 1 Posted June 10, 2010 Report Share Posted June 10, 2010 na you don t need to have a engine hoist just two trolly jacks that what i use about 3 times lol but would be much easyer with the hoist ! and i tell you when you got the gearbox off is a good thing to change the oil in that ! you really feel the diffence !! Link to post Share on other sites
Saunders82 0 Posted June 10, 2010 Report Share Posted June 10, 2010 Oil can get into the water via the oil cooler so might be worth checking that can give the same problems your having Link to post Share on other sites
vr6stormt 0 Posted June 11, 2010 Author Report Share Posted June 11, 2010 right i drained of all the oil out not one drop of water in it drained the water system flushed it took off oil cooler could`t really tell anything was wrong with it looks new and shiny put it all back together watched the water in exspansion tank and litle bubbles of oil coming to surface ahhhh...still runs ok whats going on ahhhh again.... Link to post Share on other sites
ashmk3 0 Posted June 21, 2010 Report Share Posted June 21, 2010 i too get these symptoms its very strange im yet to look at the cooler tho. Link to post Share on other sites
xyber 1 Posted June 21, 2010 Report Share Posted June 21, 2010 Apparently it the oil cooler fails the water doesn't get into the oil, it's always the oil that gets out into the coolant Link to post Share on other sites
ashmk3 0 Posted June 21, 2010 Report Share Posted June 21, 2010 right tomorrow ill attack that then. cheers Link to post Share on other sites
Bigjobbo 0 Posted June 21, 2010 Report Share Posted June 21, 2010 Pressure test the cooling system as an Oil cooler internal fault is more than likely, but if it was thick in the header tank it is gonna be a dirty system, and will require several flushes to remove a majority, and then a reflush after 1000 miles. Don't want to tell you to suck eggs, but don't flush a hot engine with cold water. :-) Link to post Share on other sites
craggsy 91 Posted June 21, 2010 Report Share Posted June 21, 2010 if its the oil cooler gone then I have one that you can have cheap...never been used as I never actually changed mine Link to post Share on other sites
ashmk3 0 Posted June 22, 2010 Report Share Posted June 22, 2010 Haha neh i wasn't going to pour cold water in. Anyway the engine iscold now so I guess it's keep filling up until the water runs clear? And hopefully going to check the oil cooler tonight see if there is anything visual I can see wrong. If Ineed a new one I'll keep you in mind Link to post Share on other sites
