sparkyjr 0 Posted May 4, 2010 Report Share Posted May 4, 2010 Right im trying to install some new indicators (relocated) the original bulbs are 21w and the new bulbs are 5w how do i mod them to work properly and if its adding resistors do they go in parrell or series and what sizes. Thanks in advance as i am baffled. Link to post Share on other sites
vr6stormt 0 Posted May 4, 2010 Report Share Posted May 4, 2010 i just done this the resistor bridges across both wires and the resistor you want is a 10ohm 30 or 50w ceramic wound, maplins dont do them this powerfull so you will have to buy it on line from rs or other they are about £1.50 each Link to post Share on other sites
rodney 17 Posted May 4, 2010 Report Share Posted May 4, 2010 look at the r32 thread... and chat to VR6stormt they are working on something similar,,, Link to post Share on other sites
sparkyjr 0 Posted May 4, 2010 Author Report Share Posted May 4, 2010 cool i take it you ment 10 ohms and 30 w or 50w?If you dont mind me asking how did you work that out???? Link to post Share on other sites
vr6stormt 0 Posted May 6, 2010 Report Share Posted May 6, 2010 sorry mate it`s a 10ohm 25watt high power wire wound resistor they are £3 from rs you need x2 one for each side and they go on to little alloy heatsink`s and then you can bolt it out the way i will edit tomorrow with the part number for the right one`s and i have some spare alloy heatsinks you can have if you want,, as for the invoice for the headlight`s couldn`t find it...i think it was called racerbitz dot com... Link to post Share on other sites
sparkyjr 0 Posted May 7, 2010 Author Report Share Posted May 7, 2010 dohh just recieved 50 w resistors, o well if you can post the part no that would be great, also that would be great about the heatsink. Keep in contact. Link to post Share on other sites
vr6stormt 0 Posted May 7, 2010 Report Share Posted May 7, 2010 dohh just recieved 50 w resistors' date=' o well if you can post the part no that would be great, also that would be great about the heatsink. Keep in contact.[/quote']yep sorry about that mate the code for RS is under high power resistor and is 119-135.drop me a pm if you need the heat-sink and i will chuck in some heat-sink compound aswell to go in-between the resistor and ally h/sink.... Link to post Share on other sites
sparkyjr 0 Posted May 7, 2010 Author Report Share Posted May 7, 2010 maybe a really stupid question but what is heat sink and can you explain the procces to include compound. Thanks Link to post Share on other sites
vr6stormt 0 Posted May 7, 2010 Report Share Posted May 7, 2010 heat-sink is the alloy part drawing the heat away from the resistor,, the compound goes between the 2 parts to get max contact between surfaces Link to post Share on other sites
rodney 17 Posted May 7, 2010 Report Share Posted May 7, 2010 correct-amundo Link to post Share on other sites
