removing a mk3 dash?
i took mine off the other day to replace the heater matrix if you just want the dash out its a row of 8 mm bolts all along the bottom edge off dash and screws behind all the bits of pop off dash blanking bits and under the scuttle panel you take off the wiper motor to get to one 10mm bolt and next to the cabin filter another one if you need to take out the frame behind the dash ie: for h/matrix its the two star bolts either side in door shuts ther are bolts behind the heat sheild on the bulk head by the down pipe if you want to talk to me about it you can call me on 02380320080
ahhhh thanks guys , im doing a heater matrix myself itook thebig star bolts out idunno how to disconnect the heater controls though, rightwhenits light tomoro ill try those bolts on the scuttle panel, i heardthatthe heater matrix isa tw*t ofa job,sooooooo true!! how long did it takeu vr6stormt
