akz786 0 Posted February 10, 2010 Report Share Posted February 10, 2010 1997 VR6 - In-Pro mk4 style ones,no problems for 2 years, except yesterday the dipped for nearside does not work, I have obviously changed the bulb and tried the new bulb on the otherside where it works. side lights and main beams work on both headlights, so strange issue...seems its the connector perhaps?My question is could this be a break in the connector or loom of headlight, anyway i can diagnose this perhaps with multimeter?Thanks Link to post Share on other sites
knight 0 Posted February 10, 2010 Report Share Posted February 10, 2010 I also have a problem like that!I´ve try everthing but in the end it was my inside light on and off switchSorry for the bad english Link to post Share on other sites
akz786 0 Posted February 10, 2010 Author Report Share Posted February 10, 2010 you mean the headlight switch? thats strange as it does activate the lights on and off, just one connector does not get power, I can check that out though....Thanks Link to post Share on other sites
akz786 0 Posted February 10, 2010 Author Report Share Posted February 10, 2010 Just remembered that I have changed the brake light switch over the weekend, with an aftermarket one as original was not working...Hmmm could this be the issue? although I cannot see a connection that the brake light circuits have with main headlights?Thanks Link to post Share on other sites
Rikki 2 Posted February 11, 2010 Report Share Posted February 11, 2010 Did you check the fuse! Link to post Share on other sites
akz786 0 Posted February 12, 2010 Author Report Share Posted February 12, 2010 and surely is was that the fuse in position 1 had half fallen out! lool - i didnt even imagine that both left and right headlights had individual fuses for dipped and main beam! oh well learning process for all ....thanks guys Link to post Share on other sites
