Leaky rear lights
I've got a leak on my rear FK Automotive lights. I removed them, and added an extra layer of foam, but they still leak.
Couple of questions:
1. What can I use to seal them better (currently using some draft excluder foam).
2. If you dropped your spanner down the side of the boot on the drivers side, between the inner skin and outer skin, near the rear lights, how would you get the spanner out? ;)
Cheers, didn't realise you could buy the seals from VW. I think I'll just do that instead of trying to seal again.
I tired getting the spanner out tonight with a magnet attached to a coat hanger. No luck, as I can't see or tell where it is!
