vr6 vs leon 20vt on rollers
Going to do a dyno day soon, and obviously can't let the vr6oc down by letting a 1.8t leon beat me on the dyno. It's meant to be 177 - 180 bhp standard.. mine pulled 180 last time i had it done.
Have done a few things since then, but nothing major, anything I can do which doesn't cost a fortune to get the bhp up a few. Every bhp counts!!
Obviously I'll run super unleaded with a couple of octane boosters chucked in for good measure.
How much BHP would a new oil and filter free up/restore?
What about engine mounts, will this effect the torque or BHP on the rollers??
Should I pump my tyres up to 50psi? or let his down without him noticing!
Was 180bhp standard with air filter in engine bay straight off the MAF, now it's got 6 branch manifold, air filter routed behind bumper with grill removed, new leads and plugs last week, coilovers (not sure it'll make difference on rollers but does on the road!!), new exhaust with smaller boxes, new timing chains that aren't a tooth out on the crank now!!
Discuss! :D
why lower pressures??
I thought that higher would decrease resistance.. for example trying to push a car on flat ground with flat tyres is harder..
i could understand incase of wheel spin on FI's incase they spin up
Thats because they grip more if you had 50psi the tyres would more than likely spin rather than grip
Same as if you are doing 1/4 mile sprints you lower the pressure to create bigger footprint of tyre on the track
i agree with you 100%... but i just didn't think that a standard aspirated VR would spin on the rollers..
Think i might stick to 30odd
