terrorste 0 Posted December 28, 2009 Report Share Posted December 28, 2009 ]Hi people.I Really thought my car was of fire earlier, but the bonnet was cold so i opened it up to find water all over the place. I found out that whenever i rev'd the engine water was squirting out of a pipe straight on to the manifold downpipe. it's the pipe thats wrapped in tape. it goes from a small inlet pipe into a t shaped big pipe one end going towards the dash and other into the engine. (sorry i'm no good explaining things)Anyone know how much this part is and how hard it is to change? part number would be helpful too.Thanks Link to post Share on other sites
Rikki 2 Posted December 28, 2009 Report Share Posted December 28, 2009 You can just snip back the small hose and block it until you get one just make sure you do the other one going to the throttle body otherwise you'll lose all your water. Its there to circulate water to stop the butterfly freezing in cold conditions. It goes to the bulkhead and is for the heater matrix if that helps dont know what its called but they pop up on ebay now and then Link to post Share on other sites
terrorste 0 Posted December 28, 2009 Author Report Share Posted December 28, 2009 Thanks Rikki I will have a go at that tomorrow. oh and in the small pipe there is like a bit of metal inside it so if i snip it back will it fit back in? Link to post Share on other sites
thegoth 5 Posted December 28, 2009 Report Share Posted December 28, 2009 the metal is on the throttle body. in that case, you might get away with cutting the pipe at the split and stretching it back onto the TB Link to post Share on other sites
RAPgolfvr6182 2 Posted December 29, 2009 Report Share Posted December 29, 2009 if ur going to cut the split out put the water pipe in hot water first for a while it expnads it making it easier to puch on Link to post Share on other sites
Rikki 2 Posted December 30, 2009 Report Share Posted December 30, 2009 yea you should be able to chop enough before the stopper in the pipe.....have no idea what its for anyway. Mines been like that for a year or 2 now lol! Link to post Share on other sites
terrorste 0 Posted December 30, 2009 Author Report Share Posted December 30, 2009 yea you should be able to chop enough before the stopper in the pipe.....have no idea what its for anyway. Mines been like that for a year or 2 now lol!Its split just after the metal stopper thoughwill the metal stopper fit back in? Link to post Share on other sites
terrorste 0 Posted January 3, 2010 Author Report Share Posted January 3, 2010 got a leak coming from near the radiator now Link to post Share on other sites
terrorste 0 Posted January 4, 2010 Author Report Share Posted January 4, 2010 Just been to the gargage across from me and had a quote to fit a new radiator and oil cooler at a cost of....... wait for it .......... £433 nationwide autocentre your a joke! £180.86 for the radiator £67.18 for the oil cooler and 170 for labour! Can anyone give me the part numbers for these so i can go gsf or main stealers? thanks once again Link to post Share on other sites
