easiest method to remove and reinstall alternator?
Same as RAPgolfvr6182 states.
If it hasn't already come off, you're going to need a lot of force to remove it after the bolts have been removed. Even with Lithium grease or copper slip, you still need a hell of a force to put the alternator back on...if you're unlucky.
Easiest way if you've a very stuck alternator is to remove the front of the car like I do for front engine work. Only takes me about 11 minutes to remove/replace everything.
It wont foul the chassis leg on removal. Unless you use it as a pivot point for a bar or something to ease it off.
If it is the original, it will usualy be very stiff to remove with the 2 bolts removed. You could be a lucky one though....just squirt some WD40 onto the bolt links to the engine and give it a lil bit.
