Camber set up after Suspension Change
you can't check over here fella.
You can use a spirit level on the front sub frame. get the car level left to right.
then use the spirit level on the hub face. use a jack to get the wishbone level (like it was on the floor) and adjust it that way.
You might as well get it lazer tracked and camber. Its one of the most important parts of a well handling car
Hope that helps
