Hello Guys VR6 Ecu code puzzle?
Hello and thanks in advance for any help.
I have a 1998 mk3 Golf VR6 OBDII. I had the error codes read when I bought it just to be sure that everything is as it should be and it threw up an error code of 029C battery terminal 30 voltage 'signal too low'
I have searched the net high and low to find an answer to this without any joy what so ever. The nearist thing to it i found was regarding a relay on a 2000 model Scoda.
Any help would be much appriciated as this is the last problem to fix on my little beuty before I start playing with cosmetics of the car.
thx' date=' so basically its remembered when i've removed the battery clip to reset the ecu?
Another point, the reason I did that was because the MFA doesnt re-set when I start a new journey? Any clues?
yeah it shows up just to warn you the battery or it's connection may be at fault if you didn't actually unplug the battery
