VR6 REBORN 0 Posted October 16, 2009 Report Share Posted October 16, 2009 Hello and thanks in advance for any help. I have a 1998 mk3 Golf VR6 OBDII. I had the error codes read when I bought it just to be sure that everything is as it should be and it threw up an error code of 029C battery terminal 30 voltage 'signal too low' I have searched the net high and low to find an answer to this without any joy what so ever. The nearist thing to it i found was regarding a relay on a 2000 model Scoda.Any help would be much appriciated as this is the last problem to fix on my little beuty before I start playing with cosmetics of the car. Link to post Share on other sites
xyber 1 Posted October 16, 2009 Report Share Posted October 16, 2009 You get that when ever the battery is disconnected Link to post Share on other sites
VR6 REBORN 0 Posted October 16, 2009 Author Report Share Posted October 16, 2009 thx, so basically its remembered when i've removed the battery clip to reset the ecu?Another point, the reason I did that was because the MFA doesnt re-set when I start a new journey? Any clues? Link to post Share on other sites
thegoth 5 Posted October 16, 2009 Report Share Posted October 16, 2009 you have it set to position 2. Link to post Share on other sites
VR6 REBORN 0 Posted October 16, 2009 Author Report Share Posted October 16, 2009 You mean the 2 point postion on the stalk? If so is it supposed to re-set if its set to position 1 and on the same matter if I flick it to the 0 postion does this re-set it also? Link to post Share on other sites
Ben Seabrook 4 Posted October 16, 2009 Report Share Posted October 16, 2009 should be at position 0 to re-set for every trip I think !!! that's where I keep mine at all the way to the left Link to post Share on other sites
craggsy 91 Posted October 16, 2009 Report Share Posted October 16, 2009 There is a 0 left and right aint there....it goes on MFA stick 0210 dont it.....been a while now since ive drove mine Link to post Share on other sites
Ben Seabrook 4 Posted October 16, 2009 Report Share Posted October 16, 2009 yeah that's what I couldn't remember that's why I said all the way to the left !!! not very technical but you get the idea Link to post Share on other sites
thegoth 5 Posted October 16, 2009 Report Share Posted October 16, 2009 position 1 is the trip counter which resets itself once the car hasn't been running for an hour or two. position 2 keeps counting until reset. holding the switch in the zero position resets which ever counter. Link to post Share on other sites
VR6 REBORN 0 Posted October 16, 2009 Author Report Share Posted October 16, 2009 OK thx for the help, in this case then I think I may require a new stalk as it doesnt matter which position the switch is in, the unit just wont reset unless i disconnect the battery terminal. Link to post Share on other sites
Ben Seabrook 4 Posted October 16, 2009 Report Share Posted October 16, 2009 ah yeah :$ :$ oops your right Nige position 1 is the one I keep it in Link to post Share on other sites
xyber 1 Posted October 17, 2009 Report Share Posted October 17, 2009 thx' date=' so basically its remembered when i've removed the battery clip to reset the ecu?Another point, the reason I did that was because the MFA doesnt re-set when I start a new journey? Any clues?[/quote']yeah it shows up just to warn you the battery or it's connection may be at fault if you didn't actually unplug the battery Link to post Share on other sites
