what else do you need for a conversion?
You will also need a corrado pedal box, with master cylinder and servo.
Alot of people say you need a corrado rad, but you can do it with the mk3 one, just cut the fan housing down and make some custom brackets!!
Solid front engine mount, or corrado crossmember with corrado mount. The solid ones where on ebay for about £30.
Brake bias valve if using the rear vr breaks. I used one that you can adjust yourself. Your donor may have a sufficiant one still on it??
