6 Branch Manifold
A wrapped 6 branch does sound good and improve the exhaust gas flow from the head' date=' especially if you go FI. De cat will reduce exhaust back pressure and adds that raspy sound under hard acceleration. The downside is that you get a little more exhaust noise and a bit of popping back on the overrun. Both of which are great imo :)
I've got the same charger as Ben on mine. Like you I had no plans to up the power much but it came up at a good price at the right time. I haven't done cams or injectors and only have the stage 1, 6psi pulley fitted along with a ported & polished head and lightened flywheel. Just made 250bhp over in Germany. The increase in torque is the major difference imo. If you can keep your schrick and fit the charger you'll have the ideal set up as the schrick switches over just as the charger goes on boost.
Whereabouts in SW are you btw? I can't be that far from you so if you fancy meeting up let me know.
Kevin
Hi Mate,
I am in Wimbledon. Would be great to meet up as I have not met anyone off here yet. Planned to be at GTI International but had a problem with my exhaust the day before so did not make it down.
Where abouts are you based?
glad you saw this Kevin :) yeah going to stick both bits on my car for the increase in flow and the noise !!
mate go out in Kev's car and your mind will be made up for you ;) ;)
I need to go out in kev's car!!! +1 for the same charger as Kev and Ben!!
Good work Ben! At this rate I could start charging. LOL. Anybody else interested? I'll be doing sightseeing tours but you'll need a good camera or most things will be a blurrrrrr......;)
Rikki, not a problem mate. Next time I'm over at Pat's we'll see what we can sort out.
Kaz, as discussed on the phone I'm only in SW17 so definately have meet up, go for a blast and discuss your "options" ;) I'd like to see what difference the Shrick and you other mods have made also.
