kemble airfield trackday 28th nov and 19th december
iv seen this on another site (jap) and though hmm i might just do that anybody else interested?
Kemble Airfield Day 28th November and 19th december 2009
Payment is £50 per car for the day and £10 for extra drivers. Limited spaces please check with Rich on launchmotorsport@googlemail.com to arrange payment direct (as I will be away on holiday so unable to sort this out)
Format of the day
Starts at 0900hrs
Morning session
A short briefing prior to the days events all persons on the day must attend this briefing.
Then follows a group familiarisation lap of a the layout
High speed bend circuit
0-60 sprint, high speed runs section opens up.
Afternoon session
Handing circuit is open (following a group familiarisation lap)
Followed by the timed runs of both the High speen bend circuit and handling circuit together.
On site facilities
* Catering burger van
* Toilet facilities
* Tyre Fitter with various tyres and alloys
RULES
1. You will not be allowed onto the site unless you sign the disclaimer, the reason for this is because your insurance will not be valid and you need to be responsible for your vehicle and any passengers that are with you.
2. No burnouts.this causes damage to the surface.
3. No racing,this is a practice day.we are not allowed to compete.
4. No drifting,this doesn’t mean no sliding though, drifting produces excessive tire squeel which upsets the neighbours.
5. Do not drive on the grass deliberately. Kemble hold regular shows and they need to keep the grassy areas in good condition.
6. Please do as the marshals ask.
7. Once inside the controlled area idle speed only.
8. Please give each other space whilst on the runway.
9. No littering.
10. Any accidental damage to property will be covered by Launch motorsport,any damage caused by negligence will be covered by the Driver concerned.
11. All drivers will attend a short briefing prior to the days events.
12. On arrival please park in designated area.
13. If you have a soft top or open topped car, Helmets will be worn and arms and legs should be covered.
14. Any one seen to being spinning wheels etc on the grass will be asked to leave.
Where
Kemble Airfield, Kemble Enterprise Park, Kemble, Cirencester, Gloucestershire, GL7 6BA.
Directions
If you go purely on satnav instructions (to get to Kemble) then be aware that they usually take you to the wrong entrance! So, assuming that you're coming along the M4, exit at junction 17 and head towards Cirencester (A429). You'll see random signs for the airfield but simply stay on the A429 all the way - you can't miss it. Launch Motorsport signs will be up from the main entrance so it should be fairly straightforward.
