bungy 2 Posted September 12, 2009 Report Share Posted September 12, 2009 I'm looking to decat my 4mo and thought it would be worth buying a cat from the breakers, removing the insides and replacing my cat with the OEM pipe with it's guts removed. I understand the 4mo has 2 lamda's with the 2nd comparing with the 1st. As the 2 readings get closer then a fault alarm will be triggered. Is it possible to overcome this? If I blank the second boss and strap the 2nd sensor up out the way will this frig the sensor into believing it is in clean air and so negate the warning? Has anyone had a go at this and how do you get it all to work?Any help advice most welcome. Link to post Share on other sites
UnitedMotorsport 55 Posted September 12, 2009 Report Share Posted September 12, 2009 Leaving the sensor in fresh air under the car wont work.You need to have the 2 post CAT sensors turned off in ECU software. Link to post Share on other sites
bungy 2 Posted September 12, 2009 Author Report Share Posted September 12, 2009 Could that be done with Vagcom? Link to post Share on other sites
UnitedMotorsport 55 Posted September 12, 2009 Report Share Posted September 12, 2009 Could that be done with Vagcom?No, VAG-COM is a diagnostic tool. Software can not be altered with VAG-COM. Link to post Share on other sites
bungy 2 Posted September 13, 2009 Author Report Share Posted September 13, 2009 Every day is a school day and i'm learning. So decat, exhaust and induction. Then go for a remap and get the post cat sensors switched off. Link to post Share on other sites
