kcw 1 Posted September 4, 2009 Report Share Posted September 4, 2009 Been looking into these seem to be the cheaper alternative to Garrett dual bb but with similar spool ups and are ultra stong, but they dont seem to have an A/R as such. The one i was looking at had some specs but they mean nothing to me can you gurus help me out, heres what i've got . . . .82mm compressor wheel56mm inducer 12cm2 T3 compressor housing Hope that means something to somebody and can help me out lolKen Link to post Share on other sites
FishWick 21 Posted September 7, 2009 Report Share Posted September 7, 2009 Compressor wheel and induder refer to the same wheel, so that one has an 82mm exducer with 56mm inducer.T3 is a common flange type, most people go with that.Without the turbine wheel diameter, it's difficult to match it to a Garret but the GT35R also has an 82mm exducer, but a larger 61mm inducer.The inducer part of the compressor wheel is what pulls air into the turbo. The Exducer then compresses it. The turbine wheel only has one role and will be quoted with a single diameter.What model of Holset is it? I can probably find out some info on it.It's the Borg Warner turbos that are tanks. Holsets are no stronger than the equivalent Garretts. Link to post Share on other sites
kcw 1 Posted September 7, 2009 Author Report Share Posted September 7, 2009 My mistake I though the holsets were truck based and therefor tanks lolThe model itself was an HX35 if that helps.Ken Link to post Share on other sites
FishWick 21 Posted September 7, 2009 Report Share Posted September 7, 2009 LOL, and I meant Borg Warners are tanks in terms of petrol engine use :-)OK, so it seems the HX35 is an old cummins diesel engine turbo, which Holset say is good for up to 280hp, LOL!But after more digging, they can make 450hp on a petrol engine as they behave very differently. The 12cm2 T3 is Holset's way of saying AR. The smaller the number, the smaller the AR. Most folk say upgrade to a 16cm2 turbine housing, or get a HX35/40 hybrid.So in other words, it's usable, but make life easier for yourself mate and stick to the tried and tested Garrett's :-)Also, if it's a diesel turbo, it may not last long on a petrol engine due to the increased heat levels. Link to post Share on other sites
kcw 1 Posted September 7, 2009 Author Report Share Posted September 7, 2009 Cheers for the advice Kev.Ken Link to post Share on other sites
