VR6-RR 0 Posted July 25, 2009 Report Share Posted July 25, 2009 Hi guys,I need some help. my outer cv joint has a broken hub spindle. I have removed it from the hub, got the boot off, but for the life of me I cannot get the joint off. I need some advice. Its driving me nuts.ThanksRichard Link to post Share on other sites
legvw 0 Posted July 25, 2009 Report Share Posted July 25, 2009 You need to un-bolt it from the gearbox, clamp the driveshaft in a vice, and then beat the outer cv off. It may sound harsh but its the truth!!! A few hard whacks with a bigish hammer should do it :-) Link to post Share on other sites
VR6-RR 0 Posted July 25, 2009 Author Report Share Posted July 25, 2009 You need to un-bolt it from the gearbox' date=' clamp the driveshaft in a vice, and then beat the outer cv off. It may sound harsh but its the truth!!! A few hard whacks with a bigish hammer should do it :-)[/quote']Seriously!? Is it a case of of undoing the bolts then just pulling out the drive shaft?I am getting nervous now, as I on Link to post Share on other sites
Bigjobbo 0 Posted July 25, 2009 Report Share Posted July 25, 2009 Like said. Glove up, and hold it straight and knock crap out of it. I use a 4kg copper mallet, no cv has failed to come off with this trusty tool. Link to post Share on other sites
legvw 0 Posted July 25, 2009 Report Share Posted July 25, 2009 You need to un-bolt it from the gearbox' date=' clamp the driveshaft in a vice, and then beat the outer cv off. It may sound harsh but its the truth!!! A few hard whacks with a bigish hammer should do it :-)[/quote']Seriously!? Is it a case of of undoing the bolts then just pulling out the drive shaft?I am getting nervous now, as I onYes, there is 6 bolts that bolt the inner cv to the gearbox flange, undo them and it will come off as 1 lump. Link to post Share on other sites
VR6BOY 2 Posted July 25, 2009 Report Share Posted July 25, 2009 Hold the CV joint straight with one hand and a big hammer in the other with the shaft in a vice and a few good taps should sort it out Link to post Share on other sites
VR6-RR 0 Posted July 27, 2009 Author Report Share Posted July 27, 2009 thanks guys going to try and get it of a little later. I will update when I have got it off.Richard Link to post Share on other sites
