Good day,
I've just changed the timing chains on my new VR6 - hopefully going to finish it tonight. I was thinking that it would probably be best to crank the engine over a few times on the starter to get the oil pressure in the new tensioner up before i let it run on it's own steam. Just wondering what the best way to do this is on a OBD2 VR6? Fuel pump fuse out job? I used to take the + lead off the coil on my G60 but the VR6 obviously has a coil pack.
Thanks in advance
