think i found my oil leak....
did my 1st oil change on the vr today.....but had it running on the ramp and it was dripping pretty bad, dnt leak when its turned off. buuuuuttttt....
if ur under the car, facing the rear, and look up at the oil filter theres a white thing on the right side of it. cant c it from top cos of inlet, but think theres 2 pipes going in it...is it an oil cooler? its dripping!!!
if i undo the nut will it have an o-ring behind that needs replacing u think?
any help appriciated, cheers
