vr6 coolant system question
hI , i am in the process of installing a transmission cooler on the vento vr6 as i am running a supercharger on an auto box and running the cooler to keep the transmission temps down under heavy load ect
The question i have is , i need to plumb into the return on the cooling system so which hose would the best to plumb into? i need the cool fluid to flow into the tranmission heat exchanger on top of the auto gearbox
its very similar set up to a oil cooler but working on the coolant side
Any idea , all installed and ready to go just need to connect the pipes up.....
