i need suspension help NOW!! going mad!
should the nut be under or on top of that cup/plate?
No mate there are two different nuts, one bolts on after the spring plate, then you insert the shock put the top mounts on followed by bolt number two, will try to dig out some pics........
right, 4 hours later and im back where i started! riding high lol! put standard ones back on.
amazak - i was watching them on ebay to lol.
believe it or not i build gearboxes for a living!! aint done suspension before tho... so going work tomoz and putting it on ramps.....WILL av them on!
cheers so much for ur help, seriously! put same post on edition 38 and they did bugger all to help!
Dont give up DanH.. It is worth the effort!
It is always worth replacing the bearings as you go. It's a forgotton set :) .
There is a how to guide in the premium members section, if I recall correctly....
Keep the faith..
craggsy, i agree.
that guide is spot on, yup - deffo think the bearings gone. wot i didnt mention that before i started the top cup sat higher anyway - not that much tho!!!
will be done tomoz tho!
sorted! had it on ramp today at work, all fitted! my mate fitted the fronts and there fine, so i must of done summit wrong! i jus fitted rears and been for drive - there great! ride quite nice too! well worth it.
cheers
