veedubyah 0 Posted May 14, 2009 Report Share Posted May 14, 2009 Hello there chaps, I have a problem if anybody can help me please. I have a '97 Highline with coilpack AAA engine and the main coolant hose, which runs directly out back of the engine just underneath the throttle body and goes through the bulkhead, this hose has split leaking coolant all over the place. Does anybody know the part number for this hose please as my local vw dealer only have a picture of the distributor cap engine which looks different to the coilpack engine. Anyone's help greatly appreciated, thanks, Martin. Link to post Share on other sites
Ben Seabrook 4 Posted May 14, 2009 Report Share Posted May 14, 2009 I think this is the part number you want mate - 1H0121157A water hose / (throttle valve housing > heat exchanger>cylinder head) should be 21 in this pic Link to post Share on other sites
VR6Nat 9 Posted May 14, 2009 Report Share Posted May 14, 2009 hahaha, beat me to it!!! Link to post Share on other sites
veedubyah 0 Posted May 14, 2009 Author Report Share Posted May 14, 2009 Thanks very much for that mate. Ive just had a quick look at the part and i could just make out the part number you have posted..thanks again Martin Link to post Share on other sites
veedubyah 0 Posted May 17, 2009 Author Report Share Posted May 17, 2009 Hi there i just want to ask you something about that hose, i've got that part now but there is a slight difference with what is on my car, this new hose has an extra fitting on it just behind the section of tubing which runs across to the throttle body, which my car doesn't have this. Do you know what this is for and can i put a cap over the hole or is there another part i can get from vw the same as what is already on my car. Link to post Share on other sites
Ben Seabrook 4 Posted May 17, 2009 Report Share Posted May 17, 2009 if yours doesn't have it then yeah I would think that you could just blank it off with no worries - if the part number on the hose matched the one you ordered I am slightly surprised they were different Link to post Share on other sites
veedubyah 0 Posted May 19, 2009 Author Report Share Posted May 19, 2009 Hi there mate, i've found out what this extra fitting is, it's for models with the climatronic air con which my car doesn't have. both part numbers are the same but the climatronic one has the letter 'a' on the end. Link to post Share on other sites
veedubyah 0 Posted May 19, 2009 Author Report Share Posted May 19, 2009 we could only make out about half of the part number on the original one thats on my car atm so we prob missed this minor detail.......oops as ya do lol Link to post Share on other sites
Ben Seabrook 4 Posted May 19, 2009 Report Share Posted May 19, 2009 ah ok cool no worries about blocking it off then mate good news Link to post Share on other sites
veedubyah 0 Posted May 19, 2009 Author Report Share Posted May 19, 2009 an when it comes to fitting it, id like to do it myself if i can ya know, it looks like a pretty straightforward task. il need to drain all the coolant 1st but which hose will be best to disconnect 1st, common sense tells me to drop it out the bottom radiator hose. is this the prop way to go about it like Link to post Share on other sites
craggsy 91 Posted May 19, 2009 Report Share Posted May 19, 2009 yep bottom hose Link to post Share on other sites
