Antihero1981 8 Posted May 12, 2009 Report Share Posted May 12, 2009 HI , i replaced my hoses today with samco ones on the vento vr.....only question is as i am not sure , some of the pipes ran into a unit above the gearbox , looks like a little water heat exchanger or something , but the samco hoses i have totally bypass that...do i have the right ones? its an auto so not sure if it makes a difference?1997 vr6 Link to post Share on other sites
thegoth 5 Posted May 12, 2009 Report Share Posted May 12, 2009 sounds like the in car heater matrix. do you have any pics to be sure? the kit number should be TCS109/C the same as for a Golf. Link to post Share on other sites
Antihero1981 8 Posted May 12, 2009 Author Report Share Posted May 12, 2009 NOT AT MOMENT......but it bypass out of one main pipe and into another Link to post Share on other sites
Antihero1981 8 Posted May 18, 2009 Author Report Share Posted May 18, 2009 FOUND OUT that the auto has a transmission cooler which comes off the rad inlet and outlet....not so good when you have manual samco hoses......so now had to order a stand alone transmission cooler from german as the not that popular in the uk and to expensive to import one from states.....well least my transmission will be a bit cooler for when i put my foot down! Link to post Share on other sites
