Does the inlet manifold have to be on when running this test as its kinda difficult to get to some of the plugs with it on.
Will it affect the outcome by having the manifold off?
Never done a compression test before so just asking
No the inlet mani does not need to be on and the engine needs to not run so disconnect something to stop it starting ie: coilpack
not that it would run with the spark plugs out but if you only had one out it might still start
  • 4 weeks later...
Had my compression tested today, results are
1: 9bar
2: 8,1bar
3: 9bar
4: 8,5bar
5: 9,1bar
6: 8bar
Doesn't sound that good, eh? Thing is I've turned on just one time per cyl for about 10sec. Would have to repeat it tomorrow. Nice one guys
