sanchez 0 Posted April 28, 2009 Report Share Posted April 28, 2009 hey all. just starting to lose the head with this scrapheap!!!!!!!!!!!!! had a problem with the car dying when its warm. then starting up 10 mins later???? got vagcom, which told me its the camshaft sensor. so replaced that!!! then it happened again. grrrrrr!! got vagcom on it again which told me its the crankshaft sensor. so just replaced that and was driving last nite and as usual it dies!!!! waited 10 mins and then away it went. 100 yards later death again. this continued until home 450 yards later!!!!!any ideas welcomed!! Link to post Share on other sites
craggsy 91 Posted April 28, 2009 Report Share Posted April 28, 2009 Sounds like an immobiliser problem to me Link to post Share on other sites
Ben Seabrook 4 Posted April 28, 2009 Report Share Posted April 28, 2009 as above it sounds like the same problem I had which turned out to be the vw immobiliser causing the car to die when warm - eventually it got worse and worse until the car would not start Link to post Share on other sites
sanchez 0 Posted April 28, 2009 Author Report Share Posted April 28, 2009 what can i do to solve the problem?? hammer-whack? Link to post Share on other sites
Ben Seabrook 4 Posted April 28, 2009 Report Share Posted April 28, 2009 no mate it either has to go back to vw to have the immboiliser checked and then re-programmed or certain tuners can bypass the alarm although it is not recommended Link to post Share on other sites
Phat VR6 3 Posted April 28, 2009 Report Share Posted April 28, 2009 ECU or fuel pump relay im 90% sure its one of these 2 Link to post Share on other sites
Ben Seabrook 4 Posted April 28, 2009 Report Share Posted April 28, 2009 ECU or fuel pump relay im 90% sure its one of these 2changed both of them on mine and made no difference - however is maybe worth it as they are a lot cheaper to replace than the immobilser problem !! Link to post Share on other sites
sanchez 0 Posted April 28, 2009 Author Report Share Posted April 28, 2009 just did vagcom on it. it says engine speed sensor, implaussible signal. time to upgrade to a mk 4 4motion me thinks! Link to post Share on other sites
sanchez 0 Posted April 28, 2009 Author Report Share Posted April 28, 2009 when the engine runs for a while when hot it cuts out. leave it 10 mins to cool a bit then it will start. when u start the engine cold it wont cut out until it reaches 90 degrees. temp related probem?? Link to post Share on other sites
Phat VR6 3 Posted April 29, 2009 Report Share Posted April 29, 2009 ECU or fuel pump relay im 90% sure its one of these 2changed both of them on mine and made no difference - however is maybe worth it as they are a lot cheaper to replace than the immobilser problem !!thought yours was coilpack related in the end? anyway doesn't make a difference. there could be a number of things wrong with it which is hard to diagnose over the internet Link to post Share on other sites
Phat VR6 3 Posted April 29, 2009 Report Share Posted April 29, 2009 when the engine runs for a while when hot it cuts out. leave it 10 mins to cool a bit then it will start. when u start the engine cold it wont cut out until it reaches 90 degrees. temp related probem?? still sound like its relay related to me http://www.golfgtiforum.co.uk/index.php?topic=2080.0 (another relay related problem thats very similar to yours) Link to post Share on other sites
Ben Seabrook 4 Posted April 29, 2009 Report Share Posted April 29, 2009 ECU or fuel pump relay im 90% sure its one of these 2changed both of them on mine and made no difference - however is maybe worth it as they are a lot cheaper to replace than the immobilser problem !!thought yours was coilpack related in the end? anyway doesn't make a difference. there could be a number of things wrong with it which is hard to diagnose over the internetnope VW immobiliser in the end was the issue that was causing the cutting out when the car got warm - almost impossible to diagnose.Worth speaking to Vince at Stealth mate again as Bodge says it is tricky to diagnose over the internet/phone but he will be able to give you some good advice Link to post Share on other sites
sanchez 0 Posted April 30, 2009 Author Report Share Posted April 30, 2009 iv changed the fuel pump relay and its been happy motoring from then!!!! if said carrys on then i would like to buy "bodge" a crate of beer or a few bottles of rose to extend my many thanks for his guidence.......... cheers! Link to post Share on other sites
sanchez 0 Posted May 2, 2009 Author Report Share Posted May 2, 2009 said did not carry on so the beer offer is removed until new solution is acquired.the car runs much better but still cuts out now and again, especially when the revs are 3000+. vagcom still reports engine speed sensor signal implaussible! testing times... Link to post Share on other sites
Ben Seabrook 4 Posted May 2, 2009 Report Share Posted May 2, 2009 if you vag-com the car when it's not running the engine speed sensor will always come up mate - have you checked the immobiliser module on vag-com for faults ?? Link to post Share on other sites
sanchez 0 Posted May 4, 2009 Author Report Share Posted May 4, 2009 iv checked the immobiliser for faults. no faults. put vagcom on it today and 00282 Throttle Position Actuator -V60 was there. it was a struggle to start but it did go. Link to post Share on other sites
Ben Seabrook 4 Posted May 4, 2009 Report Share Posted May 4, 2009 i think the throttle position sensor is on the side of the throttle body mate - this was one of the things I had to change on mine as well -they are about £40 from GSF for the sensor but not sure how much a throttle body is ?? might be worth having a look to see if someone is breaking a car and can flog you the whole piece ? Link to post Share on other sites
sanchez 0 Posted May 4, 2009 Author Report Share Posted May 4, 2009 do you think thats causing the engine cutting out issue? Link to post Share on other sites
Phat VR6 3 Posted May 4, 2009 Report Share Posted May 4, 2009 ah unlucky dude.. was worth a try. have you kept your old relay? put your old fuel pump relay back and if there the same swap your ECU relay for your new one. If that don't help its another thing to tick off the listClear the codes and see if your "00282 Throttle Position Actuator -V60" code comes back... if it does then that needs sorting, (fix the things that you know are broken first) Link to post Share on other sites
Ben Seabrook 4 Posted May 4, 2009 Report Share Posted May 4, 2009 do you think thats causing the engine cutting out issue?yeah could do mate - the throttle position can cause stalling at low revs and was defo an issue with my car - the sensor on the side was not opening and closing properly Link to post Share on other sites
sanchez 0 Posted May 5, 2009 Author Report Share Posted May 5, 2009 where is the fuel pump relay?? or what numbers are on it? Link to post Share on other sites
thegoth 5 Posted May 5, 2009 Report Share Posted May 5, 2009 bottom right. #67, 80 or 167 Link to post Share on other sites
Ben Seabrook 4 Posted May 5, 2009 Report Share Posted May 5, 2009 can also have a look at the ECU and make sure it all looks ok and the wires going into it don't look worn or the dodgy blue/green deposit's on them - can also have a read through this http://www.golfgtiforum.co.uk/index.php?topic=2080.0 Link to post Share on other sites
sanchez 0 Posted May 5, 2009 Author Report Share Posted May 5, 2009 woops i meant ecu relay. :-) iv replaced the 167 relay for the fuel pump. read that thread you said!! its a read and a half. if only everything was reliable as a volkswagen!!!!!! classic. Link to post Share on other sites
sanchez 0 Posted May 5, 2009 Author Report Share Posted May 5, 2009 furry boots is the ecu? dont have a manual. :-) Link to post Share on other sites
