HIGHLINE VR6 1 Posted April 11, 2009 Report Share Posted April 11, 2009 I OWN A 98' GOLF VR6 OBD 2. IF I WAS GOING TO PUT A SCHRICK MANIFOLD ON IT WHICH WAS A OBD 1 FITMENT WOULD I THEN BE ABLE TO RUN A 2.9 THROTTLE BODY? IS THIS POSSIBLE AND IS IT A LOT OF WORK TO DO ( DIFFERENT PIPE WORK, PLUGS OR SENSORS ) ? ANY HELP IS GRATEFULLY APPRECIATEDTHANKS, IAN Link to post Share on other sites
FishWick 21 Posted April 11, 2009 Report Share Posted April 11, 2009 Nope, OBD2 throttle is completely different, you MUST use it. 2.9 throttle won't work at all.The schrick is a 3 peice casting and you can get OBD2 specific throttle elbows, for approx £75 from Stealth Racing. Link to post Share on other sites
