Alloy fitment question?
So when you say a nice high offset is that all i really need to take into account other than the size and width? Also is there an offset which could be too high' date=' like a limit to stick too or an offset which works best?
Take this into consideration, if the wheel you are buying has an offset of 50, then you can buy adapters that are 20mm thick reducing the offset to 30 which will be fine for a vr.
So equation is :
offset - adater thickness
50 - 20 = 30 ...................
PS: Hard to find high offset wheels unless they are Merc or Porka, I have been looking around for a while :(
Google 'wheel offset calculator' and click the 1010 tires link and then using your TTs as a guide, input ...........width 7.5 Et32.
The input the details of the wheels your are looking at, but, if they need adaptors, subtract 20 from the ET as a rough guide and that will give you an idea if they'll go on or not
