f4rrs 0 Posted March 17, 2009 Report Share Posted March 17, 2009 Hi,I have a rusty door that i would like to remove from my 3 door 95 VR6.The questions are:What needs to be removed before gaining access to the hinges?Do you need to remove the bumper and front wing?If so where are the mountings for the front bumper?Looking at the front wing the top part looks easy to remove but how do you remove the bottom bit?Many Thanks in advancePaul Link to post Share on other sites
thegoth 5 Posted March 17, 2009 Report Share Posted March 17, 2009 no need to mess with any body panels at all. In the middle of the hinge there is a small grub screw, possibly covered with a cap. Undo both of those and lift the door off the hinge pins. Link to post Share on other sites
SankysVR6 1 Posted March 17, 2009 Report Share Posted March 17, 2009 Don't forget to undo the door check strap to. Link to post Share on other sites
thegoth 5 Posted March 20, 2009 Report Share Posted March 20, 2009 I had a glance at my J reg hinges earlier and they are, as usual :-( , completely different. Doesn't look like they can be simply lifted off. Link to post Share on other sites
Bigjobbo 0 Posted March 20, 2009 Report Share Posted March 20, 2009 Grub screw on the top and multi splines on the bottom, i think,check strap and loom. If your fitting a new door, strip it on the car and then take it off. Check condition of window reg while your delving. Link to post Share on other sites
f4rrs 0 Posted April 20, 2009 Author Report Share Posted April 20, 2009 Hi Guys,Just another question.The wires all seem to end up in a connector plug at the chasis side.How do these disconnect for removal?Many Thanks Link to post Share on other sites
SankysVR6 1 Posted April 20, 2009 Report Share Posted April 20, 2009 You jut need to turn the big plastic nut type thing anti clock wise Link to post Share on other sites
