russvr6 0 Posted February 25, 2009 Report Share Posted February 25, 2009 plugged my car into vagcom and got codes00515 camshaft position sensor (G40) open or short B+ intermittent00537 Lambda regulation control limit surpassed intermittentcould someone tell me what these mean plus the lambda sensor is brand new i only replaced it a couple of months ago with an OE part Link to post Share on other sites
Ben Seabrook 4 Posted February 25, 2009 Report Share Posted February 25, 2009 as your a premium member check the knowledge vault engine section for a list of the codes and there are some hints on there as well Link to post Share on other sites
craggsy 91 Posted February 25, 2009 Report Share Posted February 25, 2009 the 00515 most prob means your camshaft sensor is gone or on its way. Might as well change it. Just above coilpack it isNot a clue about lambda.....when you say OE you do mean direct from VW or OE spec from GSF/ECP Link to post Share on other sites
russvr6 0 Posted February 25, 2009 Author Report Share Posted February 25, 2009 well it was off ebay but it was in original packaging and it had the vw audi badge on the sensor Link to post Share on other sites
russvr6 0 Posted February 25, 2009 Author Report Share Posted February 25, 2009 00525 O2 Sensor - Voltage Low -G39and on the cam senor it says check CMP?? Link to post Share on other sites
thegoth 5 Posted February 26, 2009 Report Share Posted February 26, 2009 00537:http://wiki.ross-tech.com/index.php/0053700525:http://wiki.ross-tech.com/index.php/0052500515:http://wiki.ross-tech.com/index.php/00515 Link to post Share on other sites
