Mocal 13 row - Oil level?
Coolers dont take all that much and you've got a lot of safety in the oil capacity (it's about a litre between the max and min marks on the dipstick)
Mine takes well under 6 litres with a 19 row cooler.
Put 5 litres in, check the level. Top it up till it's at/near max on the stick. Run it for a few seconds. Turn it off and check it again. Top up until at/near max.
If you're super paranoid/careful then you can fill the cooler with as much oil as possible before fitting it. But it's a pita... :)
