I've had one of those days . Work was cr@p . Just finished replacing my engine so took it for a test drive .
Firstly when pulling away in first the car groans for a second then its ok . I think its the clutch only does it in first .
Any ideas ?
Secondly burst a coolant hose ! the second one of the engine swap !
My question is do your coolant hoses go taught as if under pressure once they reach full temp ?
Also what temp does your engine sit at ? Mine was about 90 degrees ?
Im worried ive air locked the system as the heater matrix pipes go almost solid when hot . Although i do get hot air from vents .
I'm losing heart with the car .
Any help appreciated
Cheers
