HELP.. vr6 turbo running like sh*t
  • 3 years later...
What you have is 2 cylinders running slighly rich, now seeing that your fuel input/usage is monitored electronicly via sensors/maf/ecu/injectors etc etc ,this means you cant adjust anything to compensate for the 2 that are offslighty other than to ensure the following
a) injectors are clean and shaping correctly
B) air-fuel filters and breathers are clean and operative
c) all associated pipeork is airtight
After the aboves been checked run the car for 20mile then re-check.
You could also do a compression test wet n dry and post ya findings here please.
Stephen
