I'm getting an odd kind of hesitation with my '97 vr6
it's onyl happening at about 1800-2000 revs, and is happening when i lift off the throttle. Its like the power takes a big step down then jumps back up again when coming back on at part throttle.
It's a bit annoying as 2k revs is exactly where i find myself alot of the time when pottering around in traffic.
I'm going to check HT leads and Coil pack then maybe the MAf (but in my experience maf problems would cause hesitation going up the rev range not down) then maybe clean cam position sensor.
After this i'm stuck, any other suggestions?
Checked the leads, werent inthe best of nick so i changed them. Checked coilpack as well which as far as i can tell is fine. no real change to the hesitation tho.
I've noticed it only does it when hot too
Stuck the car on vag com, there were some old codes on there which i cleared and nothing else came back up bar the abs sensor which i already knew about.
Pulled the MAf, problem was still there so im now officially stumped!!
