project get my vr into the 13secs at the pod
  • Replies 125
  • Created
  • Last Reply
Top Posters In This Topic
Another thing to add to the list to buy before you do chains' date=' gonna get a head of Tony as well....might as well get this stuff done.
Also what about lowering CR incase i go FI?
stick a spacer plate and metal gasket on craig, pete ran a low CR vr and still went like stink
well im using two one either side to give me 8.0 CR i think that is a bit low but hay ho ... u can use one just split the layers apart and use one layer either side as far as i`ve been told ... jim be a good man to talk to cos hes using a spacer and one gasket .... JIM u about ??
think im goin to pull the head back off mine over the winter and use just one as mine has a slight leak any way ... ur prob best staying standard CR but put ARPs on if you can afford them then if you go fi it will only cost you the price of the spacer and gaskets ... oh and labour to do it lol
