unfortunately, you cant adjust the idle speed - and if it stalling, there is something wrong...
so if you have a mate that had a VW diagnostics kit (VAG-COM) - hook it up and see if the ECU has thrown any error codes...
not worth trying to guess whats wrong, you'll end up having a list that contains any of all the engine sensors...!
Jules
i had this problem, i was told nothing was wrong with it, i changed the coil pack and it was fixed, i have since found out from this site that it is only the coil pack that does not come up on vag com as faulty,
so if they tell you nothing is wrong change your coil pack
